Defining jobs based on the agent type
Steps for defining a job for supported agents.
- Fault-tolerant agents
- To define jobs, follow these steps:
- From the navigation toolbar, click Administration>Workload Definitions>Manage Workload Definitions.
- Specify an engine name, either distributed or z/OS. The Workload Designer opens. Job types and characteristics vary depending on whether you select a distributed or a z/OS engine.
- In the Working List pane, select
- Select the category and type of job you want to create.
- For HCL Workload Automation native
jobs, click
z/OS job. See Scheduling with the Agent for z/OS.
jobs, click
- In the properties panel, specify the attributes for the job definition you are creating. For all the details about available fields and options, see the online help by clicking the "?" in the top-right corner.
- Click Save to save the job definition in the database.
- Limited fault-tolerant agent
jobs, click
- . See Limited Fault-tolerant Agent for IBMi.
jobs, click
- Agent for z/OS
jobs, click
- . See Scheduling with the Agent for z/OS.
jobs, click
- Remote engines
- To define shadow jobs, follow these steps:
jobs,
jobs,
- ForHCL Workload Automation jobs,
jobs,
See HCL Workload Automation User's Guide and Reference, section about
Job definition - Shadow jobs.
Shadow Distributed or Shadow z/OS.
See IBM Workload Scheduler for z/OS Managing the Workload, section about
Specifying cross dependencies and shadow jobs.
jobs,
- Extended agents
- In the Working List pane, select .
- For SAP jobs, . See Creating SAP Standard R/3 jobs from the Dynamic Workload Console.
- For MVS,
- For PeopleSoft, .
- For z/OS, .
- Dynamic agent and IBM® Z® Workload Scheduler agents
The steps described here for defining a job are common to all access methods.
Follow these steps:- From the navigation toolbar, click .
- For SAP R/3 jobs, ERP,
SAP Job on Dynamic Workstations. See Creating SAP Standard R/3 jobs from the Dynamic Workload Console.
SAP. See Creating SAP Standard R/3 jobs from the Dynamic Workload Console..- SAP PI Channel, see Scheduling Applications with HCL Workload Automation, section about Defining a HCL Workload Automation job that runs an SAP PI Channel job.
job types, Native
- Executable, see HCL Workload Automation User's Guide and Reference, section about Job definition - Executable jobs
- IBM® i, see "Scheduling jobs on IBM i" in Limited Fault-Tolerant Agent IBM i.
- , see IBM Workload Scheduler for z/OS Scheduling End-to-end with z-centric Capabilities.
- Remote command, see HCL Workload Automation User's Guide and Reference, section about Job definition -remote command jobs.
- For Database and Integrations job types with advanced options, Database
and Integrations,
- , see HCL Workload Automation User's Guide and Reference, section about Job definition - Database jobs.
- , see HCL Workload Automation User's Guide and Reference, section about Job definition - J2EE jobs.
- , see HCL Workload Automation User's Guide and Reference, section about Job definition - Java jobs.
- , see HCL Workload Automation User's Guide and Reference, section about Creating job types with advanced options.
- , see HCL Workload Automation User's Guide and Reference, section about Job definition - Web services jobs.
- For Business Analytics job types with advanced options, Business
Analytics,
- InfoSphere® DataStage®, see Scheduling Applications with HCL Workload Automation, section about Defining a HCL Workload Automation job to run an InfoSphere DataStage job.
- Cognos®, see Scheduling Applications with HCL Workload Automation, section about Defining jobs by using composer.
- For Cloud environments, , see HCL Workload Automation User's Guide and Reference, section about Job definition - IBM SmartCloud® Provisioning jobs
- For Access Method job types, PeopleSoft, SAP r3batch and MVS, .
- For , see HCL Workload Automation User's Guide and Reference, section about Job definition - File transfer jobs.
Note: The access method for SAP R/3 provides supplementary
features if you use the alternative steps described in Creating SAP Standard R/3 jobs from the Dynamic Workload Console and associate it to an
job. You can create native SAP R/3 Standard jobs on a remote
SAP system directly from the Dynamic Workload Console.
