Prerequisite steps to create Salesforce jobs
Prerequisite steps to create a Salesforce job definition.
Before you start to create Salesforce job
definition with HCL Workload Automation,
consider the following limitations:
- The batch Apex classes (and related methods) that you want to run with the Salesforce plug-in, must be defined with global access level, in order to make them accessible by all Apex everywhere (the public access level is not enough).
- At job definition time, only Salesforce batch Apex classes can be run. If you select a non-batch Apex class, the job fails.
To create a Salesforce job
definition, you must complete the prerequisite steps that are listed
in the following procedure.
- Register on Salesforce Server and ask for user ID and password.
- Log in to Salesforce Server.
- Create the following Apex classes that are needed for the communication
between HCL Workload Automation and Salesforce Server.
The HCL Workload Automation Apex
classes must be defined outside any package.
- Class TWSListApexClass
@RestResource(urlMapping='/TWSListApexClass/*') global with sharing class TWSListApexClass{ //This Apex class exposes the TWSListApexClass REST service //which returns a list of all known Batchable Apex classes. @HttpGet global static List˂ApexClass> doGet() { RestRequest req = RestContext.request; RestResponse res = RestContext.response; String fullName=''; List˂ApexClass> tempList = [SELECT NamespacePrefix,Name FROM ApexClass ORDER BY Name]; List˂ApexClass> result = new List˂ApexClass>(); for (ApexClass a: tempList){ if (a.NamespacePrefix==null || a.NamespacePrefix.equals('')){ fullName=a.Name; } else { fullName=a.NamespacePrefix+'.'+a.Name; } System.debug(LoggingLevel.Info, 'ApexClass: '+fullName); result.add(a); } return result; } }- Class TWSSubmitApexJob
@RestResource(urlMapping='/TWSSubmitApexJob/*') global with sharing class TWSSubmitApexJob{ //This Apex class exposes the TWSSubmitApexJob REST service //which submits an Apex class to the Salesforce server. @HttpGet global static ID doGet() { RestRequest req = RestContext.request; RestResponse res = RestContext.response; String apexClass = req.params.get('className'); System.debug(LoggingLevel.Info, 'Execute Batch:'+apexClass); Type t = Type.forName(apexClass); if (t == null){ throw new TWSException (apexClass + ' not found'); } Object s = t.newInstance(); ID batchprocessid = Database.executeBatch((Database.Batchable˂sObject>)s); System.debug(LoggingLevel.Info, 'Job ID: '+batchprocessid); return batchprocessid; } global class TWSException extends Exception{} }- Class TWSMonitorApexJob
@RestResource(urlMapping='/TWSMonitorApexJob/*') global with sharing class TWSMonitorApexJob{ //This Apex class exposes the TWSMonitorApexJob REST service //which will monitor the progress of the backend Apex job. @HttpGet global static AsyncApexJob doGet() { RestRequest req = RestContext.request; RestResponse res = RestContext.response; ID i = (ID) req.params.get('jobID'); AsyncApexJob a = [SELECT Id, Status, ExtendedStatus, NumberOfErrors, JobItemsProcessed, TotalJobItems FROM AsyncApexJob WHERE Id = :i]; return a; } }- Class TWSAbortApexJob
@RestResource(urlMapping='/TWSAbortApexJob/*') global with sharing class TWSAbortApexJob{ //This Apex class exposes the TWSAbortApexJob REST service //which will abort the Apex job on the Salesforce server. @HttpGet global static void doGet() { RestRequest req = RestContext.request; RestResponse res = RestContext.response; String jobID = req.params.get('jobID'); System.abortJob(jobID); } }
- Verify the content of the Salesforce plug-in
properties file:
˂TWA_HOME>\TWS\javaExt\cfg\˂plug-in_name>.properties
This file contains the plug-in properties that were set at installation time and that you can choose to override later. The plug-in properties are the following:
whereProxyServer ProxyServerPort pollingPeriod pollingTimeout- ProxyServer
- The IP address or the server name for the proxy server. Specify this property if you connect to the Salesforce server through a proxy server.
- ProxyServerPort
- The listening port of the proxy server.
- pollingPeriod
- The monitoring frequency. It determines how often the job is monitored during its execution. It is expressed in seconds.
- pollingTimeout
- The monitoring time. It determines for how long the job is monitored during its execution. At the end of the timeout interval, the job fails. It is expressed in seconds.
