Prerequisite steps to create IBM WebSphere MQ jobs
How to define a new IBM WebSphere MQ job definition using the Dynamic Workload Console.
To create a IBM WebSphere MQ job definition, you must first complete the prerequisite steps that are listed in the following procedure.
For more information about creating IBM WebSphere MQ job definitions, see the section about IBM WebSphere MQ Job definition - jobs, in the HCL Workload Automation User's Guide and Reference.
- Install IBM WebSphere MQ, version 7.5.
- On the IBM WebSphere MQ server
workstation, create a user to use in the HCL Workload Automation jobs
definition that is not a privileged user. On UNIX operating systems,
the user must not belong to the
mqmgroup created at installation time. On Windows operating systems, the user cannot be a member of the Administrators group. - Allow the user that is defined in step 2 to connect to its queue manager, queues, and channels. For the queue manager associated to the user, set the Display for the Administration authority, and the Connect and the Inquire for MQI authority. For more information about IBM WebSphere MQ users, see http://pic.dhe.ibm.com/infocenter/wmqv7/v7r5/topic/com.ibm.mq.sec.doc/q013290_.htm
