Exporting orchestration monitor data
You can use the export data action to download all currently visible table data into a CSV, PDF, or Excel file.
Exporting the historical data allows you to perform detailed offline analysis, thoroughly verify data integrity, and import the records into external systems for advanced reporting.
  1. Navigate to any data table in the Orchestration Monitor page.
  2. Click the Export icon.
  3. In the export window, select your preferred format (CSV, PDF, or Excel). If you select PDF, configure the additional page setup options, including Page Type, Orientation, and Font Size.
    Notes:
    • Use formatted values while exporting the data: Retains formatted values during export.
    • Automatically fit data: When you select the Automatically fit page size to data option, it automatically adjusts the page size based on the data, or you can specify the page height and width manually.
  4. Click Export to download all visible records displayed in the table.
