Configuring High Availability
How to configure, change, and share your settings repository.
Performance can be highly improved by configuring multiple instances in a High Availability configuration, so as to have multiple console instances working at the same time and with the same repository settings.
The Dynamic Workload Console is set to be always in High Availability and a front-end Network Dispatcher must be set up to handle and distribute all incoming session requests.
If you use a in High Availability configuration, when you connect to a you are not actually connecting to a specific console but to a load balancer that dispatches and redirects the connections among the nodes in the configuration. Therefore, for example, if a node fails, new user sessions are directed to other active nodes in the configuration.
To implement this kind of configuration, the Administrator must ensure that the datasource.xml, located in the following path opt/wa/DWC/DWC_DATA/usr/servers/dwcServer/configDropins/overrides, has the same configuration on every in the cluster.
For details about an end-to-end high availability configuration by using two load balancers (one between the server nodes and console instances, and the other between the server nodes and the master domain manager and backup master domain managers, see An active-active high availability scenario.
