Changing user password in the plan
How you change the user password in the plan.
A User is the user name used as the login value for several operating system job definitions. Users are defined in the database and are associated to a password.
Users need to access the workstation where HCL Workload Automation launches jobs. If you need to change the user password after having already generated the plan, you can change the password in the plan. However, the changed password is only relevant to the current plan; Jnextplan restores the user password the next time it is run.
To change a user password in the plan, perform the following steps:
  1. From the navigation toolbar, click > Security > Alter User Password in Plan.
  2. Select the engine.
  3. Enter the following information in the Alter User Password in Plan panel:
    Workstation
    The name of the workstation where the user can launch jobs.
    User name
    The user name. A user needs access to the workstation where launches jobs, and have the right to Log on as batch.
    The following formats are supported when specifying the value of the user name:
    username
    The Windows user. For example user1.
    domain\username
    The user belongs to a Windows domain. Specify the Windows domain name to which the user belongs. For example MYDOMAIN\user1.
    username@internet_domain
    The user belongs to an internet domain. The user name is in User Principal Name (UPN) format. UPN format is the name of a system user in an email address format. The user name is followed by the "at sign" followed by the name of the Internet domain with which the user is associated.
    For example administrator@bvt.com.
    When a name is not unique it is considered to be a local user, a domain user, or a trusted domain user, in that order. If you schedule a job on a pool or a dynamic pool, the job runs with the user defined on the pool or dynamic pool. However, the user must exist on all workstations in the pool or dynamic pool where you plan to run the job.
    Maximum length is 47 characters.
    Password
    The user password as defined on the computer. Maximum length is 31 characters.
    The following characters are not supported by conman altpass, when changing the user password in the plan, and when using REST APIs v1:
    • \ – Backslash
    • / – Slash (or forward slash)
    • & – Ampersand
    • + – Plus
    • = – Equals
    • # – Hash (or number sign)
    • [ ] – Space
    However, you can define passwords with special characters using one of the following methods:
    Using REST API v2
    This API version fully supports the use of special characters in password values.
    Modifying the User Definition (Model):
    You can directly modify the user password in the user definition in the model. Because the optman option enAddUser /au is set to YES by default, the modified password is immediately updated in the current plan. For more information about enAddUser /au, see enAddUser.
    Confirm password
    The user password again for confirmation.
    Versions
    Use this section to view the history of object changes and work with the different versions.
    You can run the following actions:
    Compare
    Select two different versions and compare them.
    Restore...
    Select a previous version and start the restore process.
  4. Modify the values as required and click Save to save the modified task.
