Monitoring your Scheduling Environment
Tasks to monitor the workstations and domains of your environment.
To monitor workstations and domains in your environment, you create and run monitor tasks.
Note: You must create a connection to a remote HCL Workload Automation engine,
before you can run tasks on it to obtain data.
To create a task, perform the following steps.
- In the navigation bar, click .
- In the Select Task Type panel, select the task you want to create, and click Next. You must select a task type to make the corresponding list active.
- Follow the procedure relating to the specific task you are creating.
Alternatively, you can also create and run your task by specifying a query, as described in Creating a monitoring task query.
Each task you create and save is included under the menu.
