Accepting incoming changes
In the Pending Changes view, you can accept incoming changes by performing a rebase operation.
To accept incoming changes:
Open the Pending Changes view. In the VersionVault Navigator,
select the VersionVault view in which you want
accept incoming changes. Right-click the view and select from the context menu in the VersionVault Navigator
or click the Show Pending Changes icon
on the VersionVault toolbar.
- In the Pending Changes view, click on the Accept
All Incoming Changes icon
on the Pending Changes view toolbar. -
If this is the first time that you have selected this option for the current view, the
Default Rebase Configuration dialog box displays. Specify whether to rebase to
the recommended baseline or the latest baseline and click OK.
Note that you can also specify this option in the preferences, under the When rebasing options.
- The Ready to Complete Rebase dialog box appears. Specify whether to leave the rebase operation in its current state, complete the rebase operation, or cancel the rebase operation, and click OK.
- If you chose to complete the rebase operation, click OK in
the Rebase confirmation dialog box.The Pending Changes view now shows no incoming changes.
