Entity Model build unsuccessful
Table 1. Base UI: Scenario 7
Issue Description Entity Model build unsuccessful
Modules Impacted Recommend service, iParse, Generic Service, RBA Service, Release service
Probable Root Cause HCL.iAutomate.Entity service may not be running
Resolution Steps:
  1. Press Win+R and type services.msc.
  2. Click OK to open Windows Services.
    Figure 1. Entity Model Build Unsuccessful
  3. Check if the status of the service HCL.iAutomate.Entity is Running.
  4. If the service is running, then check logs in ReportsComponent Log for more information.
