Small Environment without High Availability (HA)
In this mode, the following BigFix Runbook AI servers are deployed:
- Web and Application Server : This server hosts the Web UI and the Application components.
- Advanced AI Server: This server hosts iScrape, iKnowledge, and Advanced iKnowledge components.
- Database Server: This server hosts the SQL Server database, which is the main transactional database of BigFix Runbook AI.
MongoDB and Solr: This server hosts Document Storage (MongoDB) and Indexer (Solr).
The following table describes the hardware and software requirements for this installation.
| Server | Component | Sub-Components | Database Requirement | Recommended Hardware Configuration | Minimum RAM Requirement for BigFix Runbook AI | Software Requirements | Storage (Local) |
| Web Server + Application Server | Web Component |
NA | One Virtual Server with 2vCPU, 8 GB RAM | 4 GB RAM | Operating System - Windows Server 2016, 2019,2022 64-bit | 100 GB |
| Application Component – Microsoft Dot Net |
| Application Component - Python |
| Advanced AI Server | Advanced AI Component - Python |
NA | One Virtual Server with 2vCPU, 4 GB RAM | 4 GB RAM | Operating System - Windows Server 2016, 2019,2022 64-bit | 50 GB |
| Database Server | Database | Transactional Database | Microsoft SQL Server 2016, 2019 - Standard Edition | One Virtual Server with 4vCPU, 8 GB RAM | Not Applicable | Operating System - Windows Server 2016, 2019,2022 64-bit | 100 GB |
| MongoDB and Solr | Document Storage | MongoDB | NA | One Virtual Server with 4vCPU, 8 GB RAM | 2 GB RAM | Operating System - Windows Server 2016, 2019 , 64-bit | 100 GB |
| Indexer | Solr | NA |
The installer needs to be run on individual servers that include Web
Component, Base Component, and Advance AI Component server. In case Advanced AI components
like iKnowledge, Advanced Knowledge and iScrape are not required, only Web Server, Application
Server and Database server will be required.
Alternate Database options:
- AWS Relational Database Service (RDS)
- GCP SQL Server 2017 PaaS service
For Document storage, MongoDB as a service can be used from AWS and
GCP marketplace.
Ansible CLI Wrapper Component is installed on Ansible CLI server, it can be installed from any server.
