Small Environment with High Availability (HA)
In this mode, the following BigFix Runbook AI servers are deployed:
  • Web and Application Server: This server hosts the Web UI and the Application components.
  • Advanced AI Server: This server hosts iScrape, iKnowledge, and Advanced iKnowledge components
  • Database Server: This server hosts the SQL Server database, which is the main transactional database of BigFix Runbook AI
  • MongoDB: This server hosts the Document Storage Database (MongoDB)
  • Solr: This server hosts the Indexer (Solr)
The following table describes the hardware and software requirements for this installation.
Table 1. Small Environment with HA
Server Component Sub-Components Database Requirement Recommended Hardware Configuration Minimum RAM Requirement for BigFix Runbook AI Software Requirements Storage
Web Server
+ Application Server
Web Component
  • Web UI
  • Web API
  • KRS
NA Two Virtual Servers with 2vCPU, 8 GB RAM 4 GB RAM Operating System - Windows Server 2016, 2019,2022 64-bit 50 GB (Additional D: Drive) and 50GB shared storage (SAN / File Folder)
Application Component – Microsoft Dot Net
  • Data Collector
  • RBA Executor
  • Generic Executor
  • Release
  • Generic Listener
  • AD Sync
  • Email Service
  • DAG Service
  • Assignation Service
Application Component - Python
  • iParse
  • iUnique
  • iRecommend
Advanced AI Server Advanced AI Component - Python
  • iScrape
  • iKnowledge
  • Advanced Knowledge
  • Knowledge Rating
Database Server* Database Transactional Database Microsoft SQL Server 2016, 2019 - Standard Edition Two Virtual Servers with 4vCPU, 8 GB RAM Not Applicable Operating System - Windows Server 2016, 2019,2022 64-bit
100 GB Shared storage
(SAN / File Folder)
MongoDB** Document Storage MongoDB NA One Virtual Server with 2vCPU, 4 GB RAM 2 GB RAM Operating System - Windows Server 2016, 2019, 64-bit 50 GB (Additional D: Drive)
Solr*** Indexer Solr NA One Virtual Server with 2vCPU, 8 GB RAM 4 GB RAM Operating System - Windows Server 2016, 2019, 64-bit 50 GB (Additional D: Drive)
The installer needs to be run on individual servers that include Web Component, Base Component, and Advance AI Component server. If Advanced AI components like iKnowledge, Advanced Knowledge and iScrape are not required, only Web Server, Application Server and Database server will be required.
Alternate Database options:
  1. AWS Relational Database Service (RDS)
  2. GCP SQL Server 2017 PaaS service
For Document Storage, if *MongoDB must be made available in HA, then 3 servers will have to be provided as per the best practices. Alternately, MongoDB as a service can be used from AWS and GCP marketplace.For Indexer, if Solr has to be made available in HA, then 5 servers will have to be provided as per the best practices
Ansible CLI Wrapper Component install on Ansible CLI server, it can be installed from any server.
