BigFix Runbook AI Installation
This section explains how to install BigFix Runbook AI components using the installer on any server or standalone machine. The installer can be further used for deployment of web servers, application servers, advanced AI servers and database servers, and the underlying components.
BigFix Runbook AI implementation contains the following menus:
Before running the installer, ensure that the ‘write’ permission is
enabled for the user on the Apache24 folder.
