Not enough memory
- Symptom
- Memory error reported during the installation and the installation does not continue.
- Cause
- The memory check at the beginning of the installation determines that the computer that you are installing on does not have the required minimum memory for installation.
- Solution
- For more information about the requirements for memory, see Server requirements .
