Downloading the Linux target software
Use the Agent Downloads to run or save the file that is required for installing the Linux™ target software.
  1. Click Tools > Downloads.
  2. Click Agent Downloads.
  3. Select ibm-trc-target-9.x.x.i386.rpm.
    Where 9.x.x is the version that you want to install.
  4. Click Save.
    For more information about installing the Linux target software, see the IBM® BigFix® Remote Control Installation Guide.
