Use the Agent Downloads option to
run or save the file that is required for installing the Linux™ command-line software.
- Click .
- Click Agent Downloads.
- Select ibm-trc-cli-9.x.x.i386.rpm.
Where 9.x.x is the version that you want
to install.
- Select Save to save the rpm file
to the required location.
- Use the following command to install the command line software
$ rpm -ivh /PATH/ibm-trc-cli-9.x.x.i386.rpm
Where
PATH is the path to the location that you saved the rpm file to and
9.x.x is the version that you want to install.
- When the installation is complete edit the /etc/ibmtrct.conf file
and set your configuration.
- Set the value of ServerURL to the host name
or IP address of your IBM® BigFix® Remote Control Server
- For FIPS compliance set the value of FIPSCompliance to
Yes.
- For NIST SP800-131a compliance, set
the value of SP800131ACompliance to yes.
- Save the file.
Note: If you install the CLI tools on a computer that does
not have the target software installed, you must uninstall the CLI
tools before you install the target software. Use the following command
to remove the CLI tools.
$ rpm -e ibm-trc-cli
