Use the Agent Downloads option to
run or save the file that is required for installing the Linux™ controller software.
- Click .
- Click Agent Downloads.
- Select ibm-trc-controller-9.x.x.noarch.rpm.
Where 9.x.x is the version that you want
to install.
- Select Save to save the rpm file.
- Use the following command to install the controller software.
Where 9.x.x is the version that you want to install.
$ rpm -ivh /PATH/ibm-trc-controller-9.x.x.noarch.rpm Where
PATH is the path to the location that you saved the rpm file to.
