Send key sequences to the target during a remote control session
You can create and configure controller properties to send special keys, or often repeated sequences of special keys, to the target during a remote control session.
Property definitions
prefix.KeySequenceName=| Modifiable Field | prefix.KeySequenceName |
| Field Description | Display name that is used in the Perform Action in target menu. Each defined key sequence name must have a different prefix. |
| Possible Values | User Defined. For example,
injectF1.KeySequenceName
= Inject F1The text, Inject F1, is displayed in the Perform Action in target menu. |
| Value Definition |
prefix.KeySequenceName.language=| Modifiable Field | prefix.KeySequenceName.language |
| Field Description | Translations for display name. This property is optional. |
injectF1.KeySequenceName.es
= Inyectar F1 |
| Value Definition |
prefix.KeySequenceValue=| Modifiable Field | prefix.KeySequenceValue |
| Field Description | Macro sequence. The sequence of keys defined here is sent to the target computer. |
injectF1.KeySequenceValue
= [F1] |
| Value Definition |
Example configuration file entries
injectF1.KeySequenceName = Inject F1
injectF1.KeySequenceName.es = Inyectar F1
injectF1.KeySequenceValue = [F1]
injectCTRLALTS.KeySequenceName = Inject CTRL+ALT+S
injectCTRLALTS.KeySequenceValue = [CTRL ALT S]
injectCTRLALTX.KeySequenceName = Inject CTRL+ALT+X
injectCTRLALTX.KeySequenceValue = [CTRL+][ALT+]x[ALT-][CTRL-]
injectALTF.KeySequenceName = File Menu
injectALTF.KeySequenceValue = [alt+]f[alt-]
The following explanation can be used for any of the macros that are used. The control key is used as an example.
To press and release the control key, use [CTRL]
To press but not release the control key, use [CTRL+]
To release the control key, use [CTRL-]
Macros that you can use
| CTRLL | CTRL | CTRLR | ALT | ALTL | ALTR |
| SHIFT | SHIFTL | SHIFTR | META | METAL | METAR |
| SPECIAL | F1 | F2 | F3 | F4 | F5 |
| F6 | F7 | F8 | F9 | F10 | F11 |
| F12 | F13 | F14 | F15 | F16 | F17 |
| F18 | F19 | F20 | F21 | F22 | F23 |
| F24 | F25 | F26 | F27 | F28 | F29 |
| F30 | CAPS | SCROLL | NUM | BACKSPACE | TAB |
| UP | DOWN | RIGHT | LEFT | PGDN | PGUP |
| HOME | END | ENTER | ESC | INS | DEL |
| MENU | PAUSE | BREAK | SYSRQ | PRTSC | CLEAR |
| UNDO | REDO | CUT | COPY | PASTE | KPSLASH |
| KPSTAR | KPMINUS | KPPLUS | KPENTER | KPINS | KPDEL |
| KPEND | KPDOWN | KPPGDN | KPLEFT | KPRIGHT | KPCENTER |
| KPUP | KPPGUP | ALTGR | SYSREQ | SLEEP | APPS |
| ZOOM | STOP | CANCEL | PROPS | FRONT | OPEN |
| FIND | VOLUP | VOLDN | MUTE | POWER | CONTRAST_UP |
| CONTRAST_DN | BRIGHT_UP | BRIGHT_DN | DEGAUSS |
