BigFix Remote Control application helps to communicate between different components, clients, and endpoints within BigFix environment.
By using Remote Control you can remotely support and control thousands of PCs and servers, on an enterprise scale, from a central location or directly, in peer to peer mode.
Welcome to the BigFix Lifecycle documentation, where you can find information about how to install, maintain, and use BigFix Lifecycle.
BigFix Lifecycle is single-agent, single-console technology that provides near real-time visibility into the state of endpoints.
Following is a list of links to the BigFix Lifecycle guides in PDF format:
Use the BigFix Software Distribution applications to deploy software to endpoints across your network from a single location. Maintain control and visibility into software delivery and installation. Device owners can use the Self Service Application to manage software and other BigFix actions that are deployed to them as offers.
BigFix OS Deployment, which is part of the BigFix Lifecycle Management suite, provides a consolidated, comprehensive solution to quickly deploy new workstations and servers throughout a network from a single, centralized location. This solution saves time and money, enforces a standardized and approved image, and reduces risks associated with non-compliant or insecure configurations.
A summary of changed or new features and enhancements included in BigFix Remote Control.
The Remote Control system enables remote control through three core components—Target, Controller, and Server—with optional managed-mode services (CLI tools, Gateway, Broker) for secure or external connectivity. Targets can operate in peer-to-peer or managed mode, while the Server centralizes policies, authentication, auditing, and session launch.
Now that you understand the terms and components available in Remote Control, you can identify which components you need to install:
The Remote Control components can be installed in two ways. If you have access to the BigFix® console, use a deployment fixlet to install the components.
Remote Control provides a utility that you can use to extract the installation files that are required for each component.
To prevent unauthorized targets from registering with the Remote Control server, you can enable the secure registration feature and use tokens to authenticate the target.
The BigFix® Remote Control Target provides an installation option to install a virtual smart card reader driver. You can also install the driver by running a fixlet in the BigFix console.
After you install the Remote Control components, if you change their configuration, you can stop, start, or restart the component services.
To enable LDAP authentication, synchronization with the LDAP server must also be enabled. Edit values in the common.properties file and the ldap.properties file to enable synchronization.
The US Federal information processing standard 140-2 (FIPS 140-2) is a cryptographic function validation program that defines security standards for cryptographic modules that are used in IT software.
Remote Control version 10.0.0 components can be configured for NIST SP800-131A compliance.
You can configure target properties either during or after installation. The operating system on the target system determines which properties can be configured. The target properties determine the actions that can be carried out during a peer-to-peer session. If you set a server URL and set the Managed property to Yes, the actions are determined by the policies that are set on the Remote Control server.
This topic provides guidance on configuring anti-virus (AV) and intrusion detection system (IDS) exclusions for BigFix Remote Control on Windows, Linux, and Mac platforms. It details the specific directories and processes that should be excluded to prevent interruptions or failures during remote control sessions. Proper configuration helps ensure reliable operation and avoids common errors related to AV or IDS interference.
For more information about this product, see the following resources:
This guide is for users who want to administer Remote Control.
Use Remote Control to start remote control sessions over the internet with targets that do not have the target software installed.
Use Power Management to control, monitor, and manage conservation policies in your deployment.
BigFix Application Control provides a robust framework for managing application usage within an organization. It allows administrators to define policies that dictate which applications can or cannot be run on endpoints, thereby enhancing security and compliance.
Server Automation provides powerful automation. You can use it to sequence automation actions in steps across multiple endpoints.
HCL BigFix Virtual Endpoint Manager (VEM) enhances BigFix with centralized, unified endpoint management for hybrid cloud and data center environments, spanning virtual machines and physical endpoints. VEM delivers real-time endpoint visibility, policy-driven automation for configuration and compliance remediation, and consistent security controls to streamline IT operations, reduce risk, and strengthen regulatory compliance.
Profile Management is a WebUI-based feature of BigFix Lifecycle. It provides Security Administrators the capability to define and deploy security policies to Windows 10 and macOS devices.
