Setting connection security
The following properties define the level of security to be used on the connection to the LDAP server. Set the following parameter to simple so that the Remote Control server can communicate with most Active Directory servers.
ldap.security_authentication
Specifies the security level to use. Value can be set to one of the following strings: none, simple, strong. If this property is unspecified, the behavior is determined by the service provider.
ldap.security_athentication=simple
While most LDAP servers support simple plain text login, some Active Directory administrators require a secure connection. Remote Control supports two types of secure connections to an Active Directory server, SASL (Digest-MD5) or SSL. If you cannot connect to the Active Directory server and see the following error in the trc.log:
LDAP Authentication.exception[LDAP: error code 8 - 00002028: LdapErr: DSID-0C09018A,
comment: The server requires binds to turn on integrity checking if SSL\TLS are not
already active on the connection, data 0, vece ]
Remote Control needs to be configured for either SASL or SSL connections.
