Testing the Connection
The connection to Microsoft Entra ID can be tested with Admin > Microsoft Entra ID Configuration Utility.
When the common.properties & identity_providers.properties files are updated, reset the Remote Control application by selecting Admin > Reset Application.
When the service restarts, log on to the Remote Control server by using the SAML 2.0 Single Sign-on (SSO) with Microsoft Entra ID as the identity provider. If the entries in the identity_providers.properties file are correct, you are authenticated and logged on successfully.
