Changing the details of an Import Template
After you have created an import template you can update or change any of the information defined for it. For example you may wish to change its name or add another column to be imported. To change the details for an import template complete the following steps :
  1. Click Admin > Import Data > All Templates
  2. Select the required email template.
  3. From the Admin menu OR from the Action list select Edit selected template
    The Edit Data Import Template screen is displayed
  4. Make the required changes
    If you click the update button after you have selected the file encoding, you will need to check that the required encoding is still selected, if not re select the encoding.
  5. Click Submit
The details for the selected import template are updated.
