How targets securely authenticate with the server
After you enable the secure authentication property, you can enable targets to securely register or update their details in the Remote Control database.
New registrations
For a new target or an existing target to contact the server after the secure registration feature is enabled, use the following process to implement secure authentication:
- Create a secure registration token on the Remote Control server. Copy the token data and keep it confidential. For more information about how to create a token, see Creating a secure registration token.
- Distribute the token when you install the target. For more information, see Add a token for secure target registration.
Note: The registration token in the property
RegistrationToken which is contained in the registry key (Windows) or in the
configuration file (UNIX) is deleted as soon as the target registers to the server and obtains the
endpoint token.Updates to target entries after they register
When a target contacts the server after it registers, the following process is used to implement secure authentication:
- When the target contacts the server, it sends the endpoint token.
- If the target details on the server contain the same endpoint token, the target details are updated in the database. If the tokens do not match, the target details are not updated.
