Using Patch Management for Red Hat Enterprise Linux
You can manage Fixlets using dashboards, reports, and wizards. You can deploy, fix, and uninstall Fixlets. You can also view the breakdown of Fixlets available or needed in your deployment.
You can deploy patches from the BigFix console and view the Red Hat bulletin for a specific Fixlet. Activate an analysis to view the results of an action that is found in a log file on the endpoint.
