Target screen not visible or input not working from the Controller on macOS
Reset the macOS permissions to ensure that the Remote Control Target or On-Demand Target can work correctly.
  • If you are using the Remote Control Target application close it.
    If you close the Remote Control On-demand Target application you cannot reset the permissions, because the application is deleted from the disk automatically after the session termination and the system does not recognize the bundle ID.
  • If you are using the Remote Control On-demand Target application leave it open.
If the remote screen of the Target is not visible from the Controller or you cannot control the remote Target from the Controller (a cross is showed instead of the mouse pointer), then:If the permissions are enabled, and if you still experience the same problem (especially after you upgraded from version 9.1.4.xxxx to version 10.0.0.xxxx) perform the following steps:
  1. Close the System Settings application.
  2. Open the Terminal application.
  3. Run the following command: sudo tccutil reset All com.bigfix.remotecontrol.target or sudo tccutil reset All com.bigfix.remotecontrol.odt
  4. Restart the computer.
  5. Open the Remote Control Target or Remote Control On-demand Target application again.
  6. Enable the permissions again as explained in Enable the required macOS permissions on Remote Control target version V10.
