Entering a connection code to connect to a broker session
The BigFix® Remote Control Target for macOS can participate in remote control sessions that use a broker to make the connection. Use the following method to enter the connection code to connect to the session.
Obtain a session connection code from the controller user who is starting the remote control session. For more information about sessions that are connected by using a broker, see Starting a remote control session that uses a broker.
You can enter a connection code on the BigFix® Remote Control Target for macOS in multiple ways. To enter a connection code, complete the following steps:
  1. Choose the method to enter the connection code.
    • Click the status icon, in the right of the menu bar. Select Enter connection code.
    • Right-click the application icon in the Dock. Select Enter connection code.
    • If the Remote Control Target menu is visible, select Actions > Enter connection code.
    • If the floating toolbar is visible, select Actions > Enter connection code.
  2. Type the connection code and click Connect.
