Deploying the Linux® gateway support
You can use the Deploy Remote Control Gateway for Linux task to install gateway support onto a Linux® computer.
To initiate this task, complete the following steps:
  1. Click Deployment > Linux in the navigation tree.
  2. Click Deploy Remote Control Gateway for Linux.
  3. In the Task pane, review the description and follow the instructions in the Actions box to start the task.
    Description of what the Deploying gateway support for linux fixlet does.
  4. In the Take Action pane on the Target tab, select the relevant option for determining which targets to deploy the gateway support on.
  5. Click OK and enter your Private Key Password.
The summary screen shows the progress of the task and displays status complete when it is finished.
Gateway support is installed on the targets that you selected when you ran the deployment task. The files are installed in the /opt/bigfix/trc/gateway directory on the selected targets.
To use the gateway support, you must set up a gateway configuration for your environment. For more information about configuring the gateway, see the BigFix® Remote Control Administrator's Guide.
