Deploying the Linux® controller
You can use the Deploy Remote Control Controller for Linux task to install the controller software onto a Linux® computer.
- Click in the navigation tree.
- Click Deploy Remote Control Controller for Linux.
- In the Task pane, review the description and follow the
instructions in the Actions box to start the task.
- In the Take Action pane on the Target tab, select the relevant option for determining which targets to deploy the controller on.
- Click OK.
