Removing the Linux® controller
You can use the Uninstall Remote Control Controller for Linux task to remove the controller software from a Linux® computer.
To initiate this task, complete the following steps:
- Click in the navigation tree.
- Click Uninstall Remote Control Controller for Linux.
- In the Task pane, review the description and follow the
instructions in the Actions box to start the task.
- In the Take Action pane, in the Target tab, select the relevant option for determining which targets to remove the Remote Control controller from.
- Click OK.
