Downloading the on-demand target by using the executable file
When the ondemand.enable.executable property is enabled, the on-demand target can be installed and started automatically by using an executable file.
For more information about how the installation method is determined, see Determine which installation method is used for the on-demand target. The benefit of the executable installation method is that the target system does not require the installation of any plug-ins nor does it depend on Java™ being installed on the target machine.
After the target user clicks I agree on the landing page, the launching page is displayed.
The target user must follow the instructions on the page. Download and save the file when you are prompted and complete the steps relevant to your operating system.
Windows™ systems
When the download is complete, run the file. If a User Account Control prompt is displayed, click Yes.
Linux™ systems
Change the permissions on the downloaded file. In a terminal window within the download directory, type chmod a+x BigFixRC*. Run the file.
mac OS systems
In the Remote Control Server, check for the value of the ondemand.macos.package property.
To check that:
  1. In the Remote Control Server UI, clickAdmin > Edit the properties file.
  2. From the dropdown menu, select ondemand.properties.
  3. Check the value of the ondemand.macos.package property..
You must not change the name of the executable file after you download or extract it.
Before the session starts, the target user might be prompted to accept or refuse the session.
If the on-demand target fails to start and a failover link is provided, click If the on-demand target fails to start, please click here when instructed by the helpdesk agent. ( Java Web Start). The target is installed by using the Java™ Web Start installation method.
