Defining the temporary recording directory for a broker
You can define the directory where session recordings are temporarily stored on the broker, by configuring broker properties.
- Edit the trc_broker.properties file.
In the Windows™ operating system, the properties file is in the \Broker directory within the brokers’s working directory.
In a Windows™ system, the file is in \ProgramData\BigFix\Remote Control\Broker\.
In the Linux™ operating system, the file is in the /etc directory.
- Add the following property.
- RecordingDir
- Use this property to define the directory that the session recording
is temporarily stored on the broker if Force Session Recording is
set to Yes.
For example, RecordingDir=c:\\tmp. When you are using a backslash in the path, you must enter two backslashes.
You can also specify relative directories. For example, RecordingDir=tmp. The recording is temporarily stored in the tmp directory within the working directory of the broker.
If you do not add RecordingDir to the properties file, the recording is temporarily stored in the working directory of the broker.
