Determine which installation method is used for the on-demand target
The configuration of the on-demand installation method properties determines which installation method is used for the on-demand target.
It is strongly recommended to use the executable file installation method. The Java™ Web Start and plug-in installation methods are deprecated and will be removed soon. The ondemand.enable.plugins, ondemand.enable.jnlp, and ondemand.enable.executable properties in the ondemand.properties file are deprecated and will be removed soon.
When you configure the ondemand.enable.plugins, ondemand.enable.executable, and ondemand.enable.jnlp properties, use the following information to help you determine which installation method is used for the on-demand target.
The executable installation method is the only method available when you are using the on-demand target on a macOS device.
The installation of the Firefox plug-in does not complete successfully on Firefox Version 57 or higher as Mozilla dropped support for legacy add-ons. The support for this installation method is deprecated in Remote Control starting from Version 9.1.4. IF0003 (Build Number 0309).
Table 1. Determining the on-demand target installation method from the property values
ondemand.
enable.
plugins
ondemand.
enable.
executable
ondemand.
enable.
jnlp
Installation method that is used Failover links that are provided
Yes Yes Yes Depending on the browser that the target user is using, the plug-ins (Firefox plug-in, Internet Explorer active X, or Java™ Applet) method is used. However, if the plug-ins are not detected or the Java™ plug-in is not installed or enabled, the executable method is used. The launching page provides two failover links to be used if the on-demand target fails to start. A failover link to use the Java™ Web Start method and a failover link to use the executable method.
Yes Yes No Depending on the browser that the target user is using, the plug-ins (Firefox plug-in, Internet Explorer active X, or Java™ Applet) method is used. However, if the plug-ins are not detected or the Java™ plug-in is not installed or enabled, the executable method is used. The launching page provides one failover link to be used if the on-demand target fails to start. The failover link is to use the executable method only.
Yes No Yes Depending on the browser that the target user is using, the plug-ins (Firefox plug-in, Internet Explorer active X, or Java™ Applet) method is used. The launching page provides one failover link to be used if the on-demand target fails to start. The failover link is to use the Java™ Web Start method only.
Yes No No Depending on the browser that the target user is using, the plug-ins (Firefox plug-in, Internet Explorer active X, or Java™ Applet) method is used. No failover links are provided on the launching page.
No No No No installation method is available. A page displays the following message: Unable to run the on-demand target: No installation methods are configured on the server. Not applicable.
No No Yes The Java™ Web Start method is used. Not applicable.
No Yes No The on-demand target executable file is used. No failover links are provided on the launching page.
No Yes Yes The on-demand target executable file is used. The launching page provides one failover link to be used if the on-demand target fails to start. The link is to use the Java™ Web Start method only.
