Transferring files and directories from controller to target
When you are connected to a target in a File Transfer Mode session you can transfer one or more files or directories from the controller machine to the target machine.
To copy one or more files or directories from the controller to the target complete the following steps:
  1. Select the right pane and navigate to the location that the files or directories should be copied to on the target.
  2. Select the left pane and navigate to the location of the files or directories to be copied.
  3. Select the required files or directories. Hold the CTRL key while holding the left mouse button to select multiple items.
  4. Choose the appropriate method to complete the file transfer by doing one of the following actions
    • Drag the file or directory to the right pane. You can only do this when copying 1 item.
    • Click Copy.
The selected files or directories appear in the target file system.
File/Folder metadata is not preserved during transfer. New metadata (such as timestamps, ownership, and permissions) is created on the receiving machine when the file is written.
