Removing guidance instructions from the screen
Use the clear instructions function to remove any guidance symbols, drawn lines, or highlighted areas you have placed on the remote control session screen.
To clear instructions, click
All guidance symbols are removed from the screen.
Maximising a window on the target or performing something that
requires a repaint of the target screen may remove them.
