Configure LDAP by using the LDAP configuration utility
The LDAP configuration utility contains 4 sections that you can use to configure and test certain LDAP properties to determine the correct values for your requirements.
  • Connection
  • Group search
  • User search
  • Other settings
You must complete section 1 in the utility before you can access and use the remaining sections.
To access and run the utility select Admin > LDAP Configuration Utility.
The LDAP configuration utility is displayed.
