Creating a secure registration token
You can create a secure authentication token for secure target registration.
When the enforce.secure.registration property is set to true on the server, the target must have a secure registration token so that it can register with the server. For more information about secure registration tokens and how they are used, see Secure target registration.
To add a secure registration token to the server, complete the following steps:
- Click .
Supply the following information for the token.
The default time period starts from the current date and time until 23:59 on the next day.
- Description for token. Enter a description for the token.
- Starting on. Click the calendar pull down and select a date that the token is valid from. Enter a start time or keep the default time.
- Ending on. Click the calendar pull down and select a date that the token is valid to. Enter an end time or keep the default time.
- Click Submit.
What to do next
Before you leave the page, you must copy the registration token. Keep the
token secure and confidential.
