Assigning user groups to other user groups
Use the Manage Group Membership function to make user groups members of other user groups to create a group hierarchy. User groups are assigned the permissions and policies of the user groups they are a member of. These permissions are known as the standard or normal set of permissions. For more information about how policies and permissions are granted, see How policies are determined for a remote control session.
To add user groups to user groups, complete the following steps:
Choose the appropriate method for displaying the user group.
- Select Manage Group Membership from the Actions list on the left.
Select the user groups that you want to add the selected user groups to. Some user groups in
the list might have a plus sign in front of their name, which can be expanded to show other target
groups. If you selected multiple target groups, select one of the following options.
- replace current group membership
- add to current group membership
- delete from current group membership
- Click Submit.
