Searching for user groups
You can use the Search utility to find specific user groups or find a user group by using non-specific information. To search for a user group, complete the following steps:
- Click .The Search User Group screen is displayed.
Enter the user group information to be used in the search. Type all or part of the user group name or description that is associated with the user group. For the quickest search, type the user group name into the Search User groups field. You can also type all or part of the user group name or any other detail that is known.
- Click Submit
- If any matching user groups are found, the following information is displayed
- If the user group name is entered, the details for that user group are displayed.
- If non-specific information is entered, a list of any user groups with this information as part
of their details is displayed. Note:The information that is entered is not case-sensitive - Test matches with test.
- If no matching user groups are found, a message is displayed and the user group list is blank.
If nothing is entered in the input field and you click Submit. The list
of all user groups is displayed.
