Configuring a Windows target to use tunnel connections
- Run the regedit command at a command prompt window.
In the windows registry, go to
HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Remote Control\Target
- Right-click the ProxyURL entry and click Modify.
Type trcgw://gatewayaddress:port
in the Value data field and click OK.
Where gatewayaddress is the host name or IP address and port is the port of the gateway that the target must connect to so that it can use the tunnel connection.
- Restart the target service.
