Configuring a Linux target to use tunnel connections
Edit the trc_target.properties file and modify the ProxyURL
entry by setting it to
trcgw://gatewayaddress:port.
Where gatewayaddress is the IP address or host name of the gateway that the target connects to so that it can use the tunnel connection. Port is the port that the target must connect to so that it can use the tunnel connection.
- Save the file.
- Restart the target service.
