Creating a task to
How to create an SQL query report task to run on a distributed environment.
Use this task to define your own reports by writing or importing SQL queries for extracting data in HTML or CSV format. To create an SQL report task, perform the following steps:
  1. From the navigation toolbar, click Monitoring and Reporting > > Manage Predefined Reports, and click Create.
  2. In the Task Information panel, from the Report type drop-down menu, select Report.
  3. In the Report Header panel, choose the name and the format of the output of the report and click Next to proceed or Finish to complete the task creation using all the default values. The Report supports only the Tables View in either HTML or CSV format.
  4. In the Filter Criteria panel, enter the SQL statement on which you want to base your report. You can write the query in the text pane or load an existing query from a file by browsing to the required file and clicking Load. Click Next to proceed or Finish to complete the task creation using all the default values.
  5. In the Report Output Content panel, select the job information that you want to display in the report output. After you make your selection click Next to proceed or Finish to complete the task creation using all the default values.
What to do next
Next, run the report. For further details, see Running Dynamic Workload Console reports and batch reports.
