Predefined Reports
This topic lists the reports you can generate using the predefined reports section.
Before you can run a report to retrieve data from an HCL Workload Automation engine, you must complete the following steps:
- Create a connection to an HCL Workload Automation engine.
- Configure the to view reports, as described in Getting reports and statistics.
You can generate the following reports from the using the predefined reports in Monitoring and Reporting from the navigation toolbar in the Dynamic Workload Console.
