Clara Control Panel
Starting from Clara V2, a Control Panel is available to simplify and speed up Clara configuration.
Clara Control Panel is automatically installed together with Clara.
After Clara installation, you can access Clara Control Panel in the following ways:
  1. At the link https://<IP:PORT>/control-panel
 where:
IP is the IP address of Clara machine.
PORT is the port of Clara machine. You can skip it if you use the default port (443).
  1. From the drop-down menu of Clara chat window.
Tasks you can run from Clara Control Panel are:
Managing the Intents
Managing User Access
Managing the product environments
Customizing Clara settings
Leave feedback
