Managing the product environments
From Clara Control Panel > Environments page, you, as a Clara administrator, can add, modify, or delete the product environments that you want to manage with Clara.
You can also set a default environment.
An environment table is available for each product that you want to manage with Clara and you can switch from one to another:
Actions that you can run on each environment are:
Click the Add Environment button to add a new environment.
For each environment that you want to add, specify the following properties:
Property
Description
Notes
Product
The product type. It can be: WAd, WAz, UnO.
Environment Name
The name of the environment.
Engine Port
The port to connect the host engine.
Default: 311116.
Engine Host
The engine IP address or hostname.
DWC Host
The DWC IP address or hostname.
Optional, if you want to define a DWC environment within the product environment. (Available only for WAd product environments).
DWC Port
The Port to connect the DWC.
The credentials or API Keys to access each added environment must be defined in the Control Panel > Access Manager.
Only for WAz environments, after adding a new environment, run the following commands:
  1. docker exec -it clara-actions sed -i '197s/HWAZ/HWAz/' /app/utils/models.py
  2. docker exec -it clara-actions sed -i '205s/HWAZ/HWAz/' /app/utils/models.py
  3. docker restart clara-actions
From Clara V2.0.0.2, the support of multiple environments is available: once Clara Administrator has defined a default environment, each user, at any time, can change the environment that he wants to manage with Clara. From Clara chat window, for the enviroment currently in use, click the Change button and select a new environment. For details, see Changing the environment to work with.
Leave feedback
