Customizing Clara settings
After Clara installation, from Clara Control Panel > Settings page you can customize the following settings:
Select the corresponding icon on the Settings left hand panel.
General
Use this page to customize the following Clara general settings.
Property
Description
Notes
DWC Certificate
The certificate to integrate Clara in the Dynamic Workload Console. Click Upload to import a .cert file containing the certificate.
In Clara, this certificate is set to the default certificate of the Dynamic Workload Console. If a custom certificate is used instead, you must modify this parameter accordingly.
Time Zone
The Time Zone you are using  with Clara.
To change the time zone go to your browser settings and select your preferred time zone.
Notes:
For the steps to run on the Dynamic Workload Console, see the following topics in the Workload Automation documentation:
SMTP
Use this page to customize the SMTP Server that will be used by Clara to send email notifications.
You can enable/disable this functionality. If you choose to enable it, you must specify the following properties:
Property
Description
Notes
SMTP Host
The fully qualified hostname of the SMTP Server.
Example: smtp.gmail.com.
Connection Security
The authentication type defined for the SMTP Server. Can be TLS or SSL.
Default:TLS.
Engine Port
The Port of the SMTP Server.
Default: 587.
SMTP Username
The username sending email to the recipient specified in the Clara Credential Manager.
Example: username@gmail.com.
SMTP Password
The password associated to the username.
Translation
Use this page to enable or disable the availability of multiple languages in Clara.
Clara V2 provides multilanguage enablement through any the following Translation Services:
Note: Multilanguage enablement in Clara is obtained through machine translation. Therefore, it could sometimes produce inaccurate results.
If you are using HCL Translator and you find that the translation is not accurate, you can submit your feedback through the HCL Software portal by providing the original sentence and the correct translation.
In this way, the HCL Translator development team can use your input to re-train the language model and improve the translation quality.
HCL Translator is an API based service. It is based on Machine Learning models that have been trained and fine-tuned to understand context-specific terms or phrases used in the Workload Automation domain, thus greatly improving the user experience. It supports bidirectional automatic translation from English to French, German, Italian, Portuguese, and Spanish. For details, see: Installing and Configuring HCL Translator.
After Clara installation, you can enable/disable the support of multiple languages. If you choose to enable them, you must specify the following properties:
Property
Description
Notes
Translation Service
Can be: "Google", "Azure", or "HCL Translator".
Default: HCL Translator.
For Google:
Server URL
The URL of the translation service provided by Google.
Languages
The languages you want to use with Clara.
 Authentication file
The file that stores the Google translation service account  key.
Must be a json file. For details, see:  https://cloud.google.com/translate/docs/setup.
For Azure:
Server URL
The URL of the translation service provided by Azure.
Subscription Key
The subscription key of the Azure translation service.
For details, see: https://docs.microsoft.com/en-us/azure/cognitive-services/translator/quickstart-translator.
Region (or Location)
The region where the Azure Server is located. This parameter is also called "Location" in Azure documentation.
Languages
For HCL Translator:
Server URL
The URL of HCL Translator provided by SoFy after the HCL Translator installation.
HERO integration
Only for WAd type environments, use this page to configure Clara integration with HERO.
Clara can monitor and get information about your Workload Automation servers through HERO (HEalthcheck & Runbook Optimizer). Clara can monitor one environment at a time. For details, see: Clara monitors your servers through HERO.
Specify the following properties for the environment that you want to monitor:
Property
Description
Notes
IP Address
HERO server IP address.
Port
HERO server Port.
Default: 587.
Client Secret
The HERO Client Secret to open a HERO session from Clara.
For details about HERO Client Secret, see the topic: "Configuring security" in HERO documentation.
Default: 35355353
The credentials to access HERO must be defined in Clara Control Panel > Access Manager.
Click the Add New button and select HERO in the Product drop-down list.
Leave feedback
