Starting from V2, a Dashboard is available to simplify and speed up Clara configuration.
Clara Dashboard is automatically installed together with Clara.
After Clara installation, you can access Clara Dashboard in the following ways:
At the link https://<IP:PORT>/dashboard
where:
IP is the IP address of Clara machine.
PORT is the port of Clara machine. You can skip it if you use the default port (443).
From the drop-down menu of Clara chat window.
Tasks you can run from Clara Dashboard are:
Managing the Workload Automation environments
