Managing the Intents
Through Clara Dashboard > Intent Manager page you, as an Administrator, can manage FAQs (or intents) for both Workload Automation and Workload Automation for Z, and add your own custom FAQs  to the default ones that you get with Clara.
In the world of virtual assistants, “intent” refers to the user's intention, that is his goal or requirement for engaging with a virtual assistant.
From the search bar, you can search for one or more intents.
Default intents cannot be edited or deleted.
Custom intents can be added, edited, deleted, and downloaded.
To add new intents, you can proceed in two different ways:
In both ways, for each intent you want to add, specify the following information:
Field
Description
Note
description
The question you want to ask to Clara
response
The answer Clara must provide
learn
Insert different questions compatible with the provided answer
Needed for Clara training
To export custom intents to a .csv file, select the intents and run the Download action.
Leave feedback
