Small Environment without High Availability (HA)
In this mode, the following BigFix Runbook AI servers are deployed:
  • Web and Application Server : This server hosts the Web UI and the Application components.
  • Advanced AI Server: This server hosts iScrape, iKnowledge, and Advanced iKnowledge components.
  • Database Server: This server hosts the SQL Server database, which is the main transactional database of BigFix Runbook AI.
MongoDB and Solr: This server hosts Document Storage (MongoDB) and Indexer (Solr).
The following table describes the hardware and software requirements for this installation.
Table 1. Small Environment without High Availability (HA)
Server Component Sub-Components Database Requirement Recommended Hardware Configuration Minimum RAM Requirement for BigFix Runbook AI Software Requirements Storage (Local)
Web Server + Application Server Web Component
  • Web UI
  • Web API
  • KRS
NA One Virtual Server with 2vCPU, 8 GB RAM 4 GB RAM Operating System - Windows Server 2016, 2019,2022,2025 64-bit 100 GB
Application Component – Microsoft Dot Net
  • Data Collector
  • RBA Executor
  • Generic Executor
  • Release
  • Generic Listener
  • AD Sync
  • Email Service
  • DAG Service
  • Assignation Service
Application Component - Python
  • iParse
  • iUnique
  • iRecommend
  • Script Executor
Ansible Wrapper Ansible Wrapper Component Ansible CLI/Inside Component NA Operating System - LINUX (RHEL 8.x/9/9.7)
Advanced AI Server Advanced AI Component - Python
  • iScrape
  • iKnowledge
  • Advanced Knowledge
  • Knowledge Rating
NA One Virtual Server with 2vCPU, 4 GB RAM 4 GB RAM Operating System - Windows Server 2016, 2019,2022 64-bit 50 GB
Database Server Database Transactional Database Microsoft SQL Server 2016, 2019 - Standard Edition One Virtual Server with 4vCPU, 8 GB RAM Not Applicable Operating System - Windows Server 2016, 2019,2022 64-bit 100 GB
MongoDB and Solr Document Storage MongoDB NA One Virtual Server with 4vCPU, 8 GB RAM 2 GB RAM Operating System - Windows Server 2016, 2019 , 64-bit 100 GB
Indexer Solr NA
The installer needs to be run on individual servers that include Web Component, Base Component, and Advance AI Component server. In case Advanced AI components like iKnowledge, Advanced Knowledge and iScrape are not required, only Web Server, Application Server and Database server will be required.
Alternate Database options:
  1. AWS Relational Database Service (RDS)
  2. GCP SQL Server 2017 PaaS service
For Document storage, MongoDB as a service can be used from AWS and GCP marketplace.
Ansible CLI Wrapper Component is installed on Ansible CLI server, it can be installed from any server.
