Small Environment with High Availability (HA)
In this mode, the following BigFix Runbook AI servers are deployed:
- Web and Application Server: This server hosts the Web UI and the Application components.
- Advanced AI Server: This server hosts iScrape, iKnowledge, and Advanced iKnowledge components
- Database Server: This server hosts the SQL Server database, which is the main transactional database of BigFix Runbook AI
- MongoDB: This server hosts the Document Storage Database (MongoDB)
- Solr: This server hosts the Indexer (Solr)
The following table describes the hardware and software requirements for this installation.
| Server | Component | Sub-Components | Database Requirement | Recommended Hardware Configuration | Minimum RAM Requirement for BigFix Runbook AI | Software Requirements | Storage |
Web Server + Application Server |
Web Component |
NA | Two Virtual Servers with 2vCPU, 8 GB RAM | 4 GB RAM | Operating System - Windows Server 2016, 2019,2022,2025 64-bit | 50 GB (Additional D: Drive) and 50GB shared storage (SAN / File Folder) |
| Application Component – Microsoft Dot Net |
| Application Component - Python |
| Ansible Wrapper | Ansible Wrapper Component | Ansible CLI/Inside Component | NA | Operating System - LINUX (RHEL 8.x/9/9.7) | |||
| Advanced AI Server | Advanced AI Component - Python |
NA | Two Virtual Servers with 2vCPU, 8 GB RAM | 4 GB RAM | Operating System - Windows Server 2016, 2019,2022 64-bit | 50 GB (Additional D: Drive) and 50GB shared storage (SAN / File Folder) |
| Database Server* | Database | Transactional Database | Microsoft SQL Server 2016, 2019 - Standard Edition | Two Virtual Servers with 4vCPU, 8 GB RAM | Not Applicable | Operating System - Windows Server 2016, 2019,2022 64-bit |
100 GB Shared storage (SAN / File Folder) |
| MongoDB** | Document Storage | MongoDB | NA | One Virtual Server with 2vCPU, 4 GB RAM | 2 GB RAM | Operating System - Windows Server 2016, 2019, 64-bit | 50 GB (Additional D: Drive) |
| Solr*** | Indexer | Solr | NA | One Virtual Server with 2vCPU, 8 GB RAM | 4 GB RAM | Operating System - Windows Server 2016, 2019, 64-bit | 50 GB (Additional D: Drive) |
The installer needs to be run on individual servers that include Web
Component, Base Component, and Advance AI Component server. If Advanced AI components like
iKnowledge, Advanced Knowledge and iScrape are not required, only Web Server, Application
Server and Database server will be required.
Alternate Database options:
- AWS Relational Database Service (RDS)
- GCP SQL Server 2017 PaaS service
For Document Storage, if *MongoDB must be made available in HA, then
3 servers will have to be provided as per the best practices. Alternately, MongoDB as a
service can be used from AWS and GCP marketplace.For Indexer, if Solr has to be made available
in HA, then 5 servers will have to be provided as per the best practices
Ansible CLI Wrapper Component install on Ansible CLI server, it can
be installed from any server.
