Component Installation Prerequisites
Prior to running the installer, complete all procedures as described in Environment Planning and ensure that all the software prerequisites for the BigFix Runbook AI component installation are met.
The following table describes the software requirements to install the components.
| Server | Component | Sub-Components | Software Requirements |
| Web Server | Web Component |
| Application Server | Application Component – Microsoft Dot Net |
| Application Component - Python |
| Advanced AI Server | Advanced AI Component - Python |
| Database Server | Database | Transactional Database | MS SQL 2016/2019 /MS SQL 2022 (+) Enterprise / Standard edition 64 bit |
| MongoDB |
MongoDB | MongoDB 8.0.17 |
| SOLR |
SOLR |
| Certificates (applicable for all tiers) | SSL Certificates | ||
