Minimal Deployment Mode
In this mode, the following BigFix Runbook AI servers are deployed:
- Web and Application Server: This server hosts the Web UI and the Application components.
- Advanced AI Server, MongoDB and Solr: This server hosts iScrape, iKnowledge, and Advanced iKnowledge components along with the Document Storage (MongoDB) and Indexer (Solr).
- Database Server: This server hosts the SQL Server database, which is the main transactional database of BigFix Runbook AI.
The following table describes the hardware and software requirements for this installation.
| Server | Component | Sub-Components | Database Requirement | Recommended Hardware Configuration | Minimum RAM Requirement for BigFix Runbook AI | Software Requirements | Storage (Local) |
| Web Server + Application Server | Web Component |
NA | One Virtual Server with 2vCPU, 8 GB RAM | 4 GB RAM | Operating System - Windows Server 2016, 2019,2022,2025 64-bit | 100 GB |
| Application Component – Microsoft Dot Net |
| Application Component - Python |
| Ansible Wrapper | Ansible Wrapper Component | Ansible CLI/Inside Component | NA | Operating System - LINUX (RHEL 8.x/9/9.7) | |||
| Advanced AI Server + MongoDB + Solr | Advanced AI Component - Python |
NA | One Virtual Server with 2vCPU, 8 GB RAM | 8 GB RAM |
Operating System - Windows Server 2016, 2019,2022 64-bit Mongo DB + Solr |
100 GB |
| Document Storage | MongoDB | NA | |||||
| Indexer | Solr | NA | |||||
| Database Server | Database | Transactional Database | Microsoft SQL Server 2016 - Standard Edition | One Virtual Server with 4vCPU, 8 GB RAM | Not Applicable | Operating System - Windows Server 2016, 2019,2022,2025 64-bit | 100 GB |
Remember:
The installer needs to be run on individual servers
that include Web Component, Base Component, and Advance AI Component server. If Advanced AI
components like iKnowledge, Advanced Knowledge and iScrape are not required, only Web Server,
Application Server and Database server will be required.
Alternate Database options:
- AWS Relational Database Service (RDS)
- GCP SQL Server 2017 PaaS service
For Document storage, MongoDB as a service can be used from AWS and
GCP marketplace.
Ansible CLI Wrapper Component install on Ansible CLI server, it can
be installed from any server.
